Home > Message Board > Home Audio > Speakers > Archive through July 21, 2008 > Infinity classia C336
Author Thread: Infinity classia C336
Username: Flek37
Hello all, its my 1st time that i am buying some speakers and i need some help, I am thinking of buying new Infinity classia C336 and proper amp for it and i am thinking of new marantz PM7001. really need someone to help me out with some advice. I dont know is the amp enough so speakers can gief their best or i need to change the amp. but i dont think i can afford something more expensive.
Username: Stefanom
Vienna, VA
United States
Post Number: 1190
Have you listened to the speakers? If so, what did they use to drive the speakers?
Username: Flek37
I didnt listen to them, they will arive to shop in my country in 2 or 3 weeks, no reviews online yet, but i know that they are impruved infinity ALPHA 50, or the next generation of that rank of speakers , i dont know nothing more at the moment.
Username: Stefanom
Vienna, VA
United States
Post Number: 1198
The best advice would be to wait until you can demo them before you worry about much else.
Username: Flek37
but im not sure is this to much for my 5 x 3 meters room, i want good sound quality but i think 250 watt is bit too much.
Username: Stefanom
Vienna, VA
United States
Post Number: 1199
Don't worry about the "250 watt" thing. When the speakers arrive at the dealer, demo them. Ask the dealer the questions you have regarding room size. Listen to a few different options regarding the amplifier (and a few other speakers as well). Then you can make a decision.
Username: Flek37
okay thank u for ur time.
Home > Message Board > Home Audio > Speakers > Archive through July 21, 2008 > Infinity classia C336 [ « Previous ] [ Next » ]
