Thread: Having an issue with my Infinity center channel speaker |
New member Username: Timver
Post Number: 1 Registered: May-08
| Posted on Tuesday, May 13, 2008 - 10:57 pm: |
I have an Infinity center channel speaker (Not sure on model)and two rear Bose speakers (the two small cubes). For a Tunner I have a Pioneer VSXD1S, I have been having an issue with the center channel and need some help. What happens is I will be watching TV, Movie ect and sound is great then center channel audio goes to a lower volume for anywhere from a minute to 3 minutes and then it goes back to normal for ever sometimes or 30 minutes and then back to low and so on. What is doing this I checked the cable and it is fine. Thanks |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 925 Registered: Feb-07
| Posted on Wednesday, May 14, 2008 - 09:43 pm: |
I doubt it's your speaker. More likely the center channel section on your receiver that's acting up. |
Post Number: 2 Registered: May-08
| Posted on Friday, May 16, 2008 - 12:51 am: |
how do I check it to see if it is and fix it? |
Ottawa,
Ontario
Post Number: 926 Registered: Feb-07
| Posted on Friday, May 16, 2008 - 08:29 am: |
You could swap out one of your front speakers for the center and see if the same behavior continues. If it does, then you know it's the receiver and not the speaker. |
Post Number: 3 Registered: May-08
| Posted on Friday, May 16, 2008 - 10:18 am: |
Ok so far no front speaker, I just have center and two rear speakers. Ideas on two nice center channel speaker and a sub? Also if it is the tunner, what is a nice one to replace it with? Thanks |
Ottawa,
Ontario
Post Number: 927 Registered: Feb-07
| Posted on Friday, May 16, 2008 - 10:35 am: |
That's a rather unconventional setup you have there Tim. Did you mean ideas on two nice front speakers? How old is the receiver? |
Post Number: 4 Registered: May-08
| Posted on Friday, May 16, 2008 - 08:18 pm: |
Yes, Ideas on front speakers and a sub woffer. The reciever was bought back in 1991, so it is old but has a ton of hook up's and options. Pioneer makes nice stuff, I think. Thanks |
Ottawa,
Ontario
Post Number: 928 Registered: Feb-07
| Posted on Friday, May 16, 2008 - 09:03 pm: |
I have a Pioneer too. I like it. But seriously, time to pick up a new receiver. |
Post Number: 5 Registered: May-08
| Posted on Saturday, May 17, 2008 - 12:00 am: |
Ok so what do you recomend for a recieiver,front speakers and a sub?? Packages or all by themselves is ok. Thanks |
