Thread: NAD 753 - HELP! Another glitch |
New member Username: Dgowen
Post Number: 7 Registered: Jan-07
| Posted on Friday, May 09, 2008 - 03:21 pm: |
Thanks for help a year ago re: resetting the firmware by pushing VIDEO6 and SOURCE. I have had to do that 3-4 times, and after the most recent one, I had 2 problems: 1) It changed some Input Settings (COAX3 to Optical 1), which I just changed back today, and 2) I have STEREO as the ONLY LISTENING MODE!?! I've tried pressing the "surr. mode" button on the remote, and physically pressing the "surround mode" button on the unit, and the only option is STEREO. When I try and scroll through the onscreen menu, there are NO OTHER OPTIONS! In the past I've used EARS, etc. , and can see the LED lights search for those modes when starting up a DVD, but I can never scroll and get options other than STEREO. Any thoughts? No sound is coming through center or any rears (Sub - yes, but that has a separate "on" toggle on the menu.) Dennis |
Gold Member Username: Nickelbut10
Post Number: 1510 Registered: Jun-07
| Posted on Friday, May 09, 2008 - 03:27 pm: |
Dennis it sounds like the Unit's firmware is messed up. Call NAD, and they will instruct you on downloading the firmware and getting it back on track. |
Platinum Member Username: Nuck
Post Number: 10215 Registered: Dec-04
| Posted on Friday, May 09, 2008 - 04:15 pm: |
Call the factory for sure. Some reload must be lurking about. |
Gold Member Username: Mike3
Wylie,
Tx
Post Number: 1283 Registered: May-06
| Posted on Sunday, May 11, 2008 - 12:08 am: |
Since it is the weekend might not hurt to check to see if the unit defaulted to a two speaker set up. If it has, correct it to the proper speaker configuration and it should then present you with the options you had before. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2919 Registered: Sep-04
| Posted on Monday, May 12, 2008 - 10:28 am: |
To me, this sounds like the 753's RAM is having problems keeping its settings so this is not just a firmware issue - I suspect hardware. Call NAD or your dealer. |
