Thread: Rackmount amplifiers |
New member Username: This_n00b_again
Post Number: 1 Registered: May-08
| Posted on Monday, May 05, 2008 - 02:42 am: |
you know those rackmount amplifiers used in pro audio, 19" ones? i was thinking about putting one in my rack which has a rackmount pc. but i was wondering, do those amplifiers give off some kind of magnetic field or some kind of radiation that wouldn't be good for the computer? Or do you see any other issues coming up? |
Gold Member Username: Nickelbut10
Post Number: 1488 Registered: Jun-07
| Posted on Monday, May 05, 2008 - 08:05 am: |
No issues there, but they can give off a lot of heat. I wouldn't place it right above, or right below the PC if possible. I too have a Rack Mounted PC I built. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 902 Registered: Feb-07
| Posted on Monday, May 05, 2008 - 12:21 pm: |
PCs dislike heat even more than audio components. You can even check your CPU's temperature through the BIOS (on most machines) if you're concerned. |
Post Number: 2 Registered: May-08
| Posted on Monday, May 05, 2008 - 09:31 pm: |
im not as worried about the heat problem, i can find a way to fix that, more worried about magnetic fields given off by big power transformers. |
Post Number: 1495 Registered: Jun-07
| Posted on Monday, May 05, 2008 - 10:37 pm: |
Your fine. I wouldn't worry about that at all. Trust me.lol. |
Post Number: 3 Registered: May-08
| Posted on Tuesday, May 06, 2008 - 05:05 am: |
roger that. thanks |
Silver Member Username: Magfan
Post Number: 212 Registered: Oct-07
| Posted on Wednesday, May 07, 2008 - 03:56 am: |
I would try to keep the hard drive away from Hi-power transformers. I don't know how much or large the stray field of a torroid is, but a conventional transformer will kill a drive if you get it too close. |
