Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Receiver for Paradigm or PSB speakers
Author Thread: Receiver for Paradigm or PSB speakers
Username: Kothrush
Post Number: 16
I am looking for a receiver for either Paradigm or PSB speakers. I have listen to paradigms Monitor 9 and I'll audition PSB Image series soon before deciding between them. I would like to get some idea about what receiver would go well with them ?
My first thought was to have NAD, but may be higher end Onkyo or Denon should also go well with them ? The receiver should be surround sound (5.1 at least) capable and should have HDMI to connect to my HDTV. I looking for something around $1000 for receiver , I hope that gives me good receiver to pair with those speakers.
If someone has experience with those receivers and speakers combination, please share your opinion.
Thanks.
Username: Nickelbut10
Post Number: 1484
NAD goes well with Paradigm and especially PSB. I know from experience on that one. Look at the Onkyo line though and take a listen to see what you think. They are a very good AVR as well. IMO I can't stand the sound of anything Denon makes but thats just my ears, doesn't mean you might not like it. Rotel AVR's go well with Paradigm as well. Best thing for you to do is go out and audition some stuff, see what you like the best.
Username: 519sledr
I recommend an NAD receiver - they do work well with Paradigms
Username: Kothrush
Post Number: 17
thanks, it seems NAD goes well with both. It seems NAD might be pushing my $1k budget for surround sound HDMI receiver. I need to look into Onkyo and H/K too I guess.
Username: Kothrush
Post Number: 18
multi channel nad is gonna cost me more than $2k. It seems its time to look into onkyo. I think psb needs 4 ohm connection. Any idea how well onkyo drives those speakers?
Post Number: 1519
Onkyo will drive them just fine. The NEW NAD line is expensive. It is better in every way than their last offerings but still pricey IMO. Best bang for your dollar right now is the Onkyo AVR's.
Username: Kothrush
Post Number: 19
Onkyo TX-SR805 around $1k seems to be be powerful enough to drive NAD. I guess I need to find a dealer and listen to onkyo, see how I feel compare to NAD. If anyone has experience with this receiver please let me know.
Post Number: 1521
Frank will be along as he has lots of experience with that receiver.
Username: Taderbutt
Oregon
United states
Get some older rotel stuff.
Username: Dmitchell
Ottawa, Ontario
Post Number: 964
Older Rotel stuff may not have the HDMI connections the OP wanted.
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Receiver for Paradigm or PSB speakers [ « Previous ] [ Next » ]
