Thread: Looking for info re: nad 1600 |
New member Username: Backabeyond
Post Number: 1 Registered: May-08
| Posted on Friday, May 02, 2008 - 12:52 pm: |
hi, i need to replace the power transformer on my nad 1600. does anyone out there happen to have a service manual on this receiver? nad isn't selling power transformers for it anymore and they charge an arm and a leg for the service manual. i'm trying to find out the ac voltage coming out of the power transformer so i can make do with something else. anyone who can share an info would be much appreciated. |
Relevant Product Info
Silver Member Username: John_ashman
Albuquerque,
NM
United States
Post Number: 215 Registered: Apr-08
| Posted on Friday, May 02, 2008 - 06:23 pm: |
I'm assuming you realize that it's not technically a receiver - no power amps. Best thing to probably do, assuming you can't find a manual, is buy a used one and make the easy transplant. They shouldn't sell for more than $100 these days. Are you sure it's a transformer? |
Silver Member Username: Magfan
Post Number: 203 Registered: Oct-07
| Posted on Saturday, May 03, 2008 - 03:30 am: |
If I remember....NAD1600 was a tuner/preamp from mid/late 80's? Manuals available online, for a price. Careful, though, as quality is variable. A good print is essential to read 'the fine print'......some component values...etc. If you are near a 'major city', there may be a shop that already has such a manual. If they DON'T (likely) make giving them the manual part of the negotiation for cost.... |
Post Number: 2 Registered: May-08
| Posted on Saturday, May 03, 2008 - 10:52 pm: |
ah, thanks for the advice. i did just find a couple places online that sell the manual, but i'll try to make sure that the quality is good before buying. |
Post Number: 3 Registered: May-08
| Posted on Saturday, May 03, 2008 - 10:54 pm: |
john, yeah, i'm pretty sure it's the transformer. i'm hoping that buying a manual online and getting another part is going to cost a lot less than $100, but we'll see... |
