Home > Message Board > Home Audio > Subwoofers > Fi sub
Author Thread: Fi sub
Username: Nvmyboom
Post Number: 319
I have a 12" Fi ssd 1 ohm sub. is there an amplifier i could run it on for indoor use?
Relevant Product Info
A pic is worth
1000 posts!!
Post Number: 16427
Try a plate amp. Google it and you'll see. 1 ohm will be tough to find.
Username: Arande2
Rattle your ...
Missouri
Post Number: 2824
Many stereo professional amplifiers have the capability to bridge or parallel their outputs, allowing for flexibility in what is connected to them.
Parallel outputs would allow twice the current to flow, so should allow 1-ohm.
Username: Magfan
Post Number: 208
Most any of these should supply enough current.
Why would anyone want to deal w/1ohm?
http://www.welders-direct.com/home.htm?gclid=CPOyofisi5MCFQyOggod6kEChg
Username: Nvmyboom
Post Number: 320
^"Why would anyone want to deal w/1ohm?"
its cause i have two of them and had them hooked up to a mono block amplifier
Username: Magfan
Post Number: 215
You can wire them in series or parallel.
A pair of 2 ohm drivers in parallel is 1ohm while in series, a more reasonable 4ohm.
DVC woofers can be wired either way, too, depending on the available amp.
Username: Nuck
Post Number: 10196
Very few, if any, amps will drive a 1ohm load.
Username: Magfan
Post Number: 216
Nuck, there ARE a few which will easily drive 1 ohm loads.
Lincoln
Hobart
Miller
All will drive very low impedence loads.
You could probably even weld with them!
A pic is worth
1000 posts!!
Post Number: 16617
But 1 ohm for home use is.......well......
ya know.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Subwoofers > Fi sub [ « Previous ] [ Next » ]
