Thread: Anyone ever use one of these? |
New member Username: Holger
Post Number: 8 Registered: Apr-08
| Posted on Thursday, May 01, 2008 - 04:52 pm: |
Anyone ever use one of these or know someone who has? http://www.6moons.com/audioreviews/gem/dandy.html My concern would be getting the lables wet. If there's even the slightest gap or pucker in the "splash guard", water will find its way in. |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12598 Registered: May-04
| Posted on Thursday, May 01, 2008 - 05:13 pm: |
. If money is your concern, there are instructions for a more "conventional" vacuum LP cleaner on the web. Otherwsie, go to the Audio Advisor site and order the Disc Doctor's machine for $199. |
Post Number: 10 Registered: Apr-08
| Posted on Monday, May 05, 2008 - 07:54 am: |
Hi Mr. Vigne, thanks for your reply. Did you mean the Nitty Gritty Record Doctor available at Audio Advisor for $299.99? I googled Disc Doctor but it didn't return any useable links. There's a cleaning solution called Disc Doctor but the company that makes it doesn't offer any vacuum apparatus. |
