Home > Message Board > Home Audio > Speakers > Interconnect length affecting perform...
Author Thread: Interconnect length affecting performance
Username: Fredrico_alvarez
Post Number: 12
I read somewhere that interconnect length can affect performance. Not as in signal loss over long runs like across your house, but as in a .5m cable sounding worse than 2m cable (2m was the supposed optimal length). I kind of laughed to myself and went on, but then I wondered if there actually was a difference. The next time I was at a hi fi store I decided to test the claim. The system consisted of high end classe delta electronics and B&W 800Ds, the best he had. I A/Bed the two interconnects of the same line of the same company, but one was .5 m and the other was 2m. At first I heard no difference. Then I noticed a very slight difference similar to more headroom on an amp. Has anyone else tried this same experiment and found different (or the same) results?
PS I know this probably isnt the right part of the forum but there wasnt one called interconnects and cables and this one looked like the one to put homeless stuff.
Relevant Product Info
Username: Nuck
Post Number: 10102
AR, if both cables are the same brand and model, I doubt you would notice a difference***
However, if they are 2 different types/models, then sure, there could be a world of difference!
*** If the same model is matched to the capacitance of a componant to create a more specific circuit(Naim), then there may be a diference yet.
Username: Nuck
Post Number: 10104
Post Number: 13
The cables were the exact same cable, same model, manufacturer and everthing, except for length. The difference was so slight it could have been mental though.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Speakers > Interconnect length affecting perform... [ « Previous ] [ Next » ]
