Home > Message Board > Home Audio > Speakers > Archive through April 28, 2008 > Using 6 Ohm Speakers on 8 ohm Onkyo R...
Author Thread: Using 6 Ohm Speakers on 8 ohm Onkyo Reciever
Username: Sakura211
I was wondering if it would be okay to use 6 ohm speakers on my 8 ohm receiver
My reciever is a Onkyo HT-R520 6.1 channel 1000 watt reciever with 130 watts per channel.
I currently have the SDAT E70 floor standing speakers and I wanted to try the
LEB-404 ones but i was worried about using them since they are only 6 ohms.
Username: Artk
Albany, Oregon
Post Number: 6769
On all but the most ballsy AVR's (multi channel receivers) I would stick with 8 ohm speakers. Appears to have been a few problems with your model in the past so I would play it safe.
Home > Message Board > Home Audio > Speakers > Archive through April 28, 2008 > Using 6 Ohm Speakers on 8 ohm Onkyo R... [ « Previous ] [ Next » ]
