Home > Message Board > Home Audio > Integrated Amps > REGA MIRA3-PROBLEM
Author Thread: REGA MIRA3-PROBLEM
Username: Mirod
Hi all,
I have problem with this amp. After 2-3 hours i can hear a noisy crack from one speaker.This is my second rega mira3 whith the same problem. Did anybody have this kind of issue whith rega.
Thanks for your advice
MiroD
Relevant Product Info
Username: Nuck
Post Number: 10083
MD, is this unit a replacement for an original Rega with the same problem?
Username: Mirod
Yes, it is replacement with the same problems.First one had problem with left channel and now i have this problem with right channel.
Username: Nuck
Post Number: 10085
How very odd.
Have you refreshed your speaker runs in the last while?
Username: Artk
Albany, Oregon
Post Number: 6729
I have a 3 and haven't had any issues at all...sorry to hear that you are. If you determine that it's the 3 then work with your dealer for resolution if they are difficult then call the distributor directly...The Sound Organization in Dallas and they will help. Good Luck.
Username: Mirod
I tried differend cables and speakers with same results.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Integrated Amps > REGA MIRA3-PROBLEM [ « Previous ] [ Next » ]
