Home > Message Board > Home Audio > Amps > Archive through October 31, 2003 > NAD A/V receiver and Outlaw Amp Combo...
Author Thread: NAD A/V receiver and Outlaw Amp Combo. Hawk, G-Man, anyone?
shaun6142
Tell me which would be better.. A NAD T762 with 6 channels for about $1100 for my 4 ohm Polk LSi series 5 channel set-up. OR, a NAD T742 with 5 channels AND 2 Outlaw Audio M200 Monoblocks for the front LSi 15s about $1200-$1300 total. But I want that 6th channel (rear center) in the future, the 742 wouldn't be a good choice then would it?? Im not really sure how the seperate amps hook up anyways. Lookin for the most power, obviously.
Relevant Product Info
shaun6142
OR, Maybe the NAD T742 A/V receiver and the 2 channel NAD C370 Amp for about $620, instead of the 2 Outlaw amps, I think the NAD amp is rated at 340 watts into 4 ohms.
G-Man
The separates hook up the same way as having any separate amplifier. I would be suprised if there aren't sufficient outputs on the back of either NAD to accommodate any combination of amplifiers.
That said, if you are using a self-powered subwoofer in this set-up, I can't imagine that the NAD 762 isn't more than adequate to drive all the other speakers.
Also, you can always add 2 Outlaw Monoblocks or a NAD stereo amp at a later date if you sense any clipping--which I think is highly unlikely.
Is there a supply of power even running directly to the speakers from the receiver to help the seperate amp if a seperate amp is present?
No
Hawk
shaun6142:
I would get the 762. I think you will find that it has all the power you need for your Polk LSi speakers (at 4 ohms, the dynamic power of the 762 is 230 wpc x 6).
However, if you still want more power, get the 752 (not 742) now and then add the NAD 270 outboard amp later when you want to add a sixth channel. Use the 270 outboard amp to power the front main speakers and use the onboard amps to drive the rest of your six channel system. I checked the NAD manual for the 752 and it appears that it can be configured in this way.
However, I agree with G-Man that I would be very surprised if the NAD 762 receiver, by itself, would not be enough power.
shaun6142
Thanks guys, guess I just underestimated the 762s power output
shaun6142
If you added the 2 monoblocks later then would it be possible to bi-amp the fronts with the A/V receiver and the monoblocks, would there be a big difference, or if you added the stereo amp would you get the same results?
Home > Message Board > Home Audio > Amps > Archive through October 31, 2003 > NAD A/V receiver and Outlaw Amp Combo... [ « Previous ] [ Next » ]
