Thread: Small bedroom setup |
Silver Member Username: Tpizzle
Post Number: 528 Registered: Apr-05
| Posted on Tuesday, April 15, 2008 - 09:54 pm: |
I wanted to put together a bedroom setup. I am assuming I need a receiver, speakers, cd player, and cables. I do not have a budget but dont need anything too hi end due to having an already much nicer 5.1 setup upstairs. I will likely go the internet route also so please recommend some components that I can research. We mostly listen to rock, jazz, and pop music. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 846 Registered: Feb-07
| Posted on Wednesday, April 16, 2008 - 08:47 am: |
Check out the Outlaw RR2150. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2881 Registered: Sep-04
| Posted on Wednesday, April 16, 2008 - 10:15 am: |
A budget would help. Also, does it need to be neat? Would you prefer a system which has a little less impact on the room than a full separates? I'll assume so for now with these recommendations: Onkyo CS715 with Totem Dreamcatchers Arcam Solo with Dynaudio Audience 42s Arcam Solo 2.1 with either of the above speakers or perhaps something a touch better If in the UK, look closely at the Meridian F80 - amazing and sounds way better than many similarly priced full separates systems! http://www.thef80.com Regards, Frank. |
