Thread: Problems with optical audio(pioneer) |
New member Username: Potatohead917
Post Number: 1 Registered: Apr-08
| Posted on Tuesday, April 15, 2008 - 07:42 pm: |
I have a vsxd912 and it detects the signal just fine(cable box/dvd) and does not produce sound. Flip over to analog(cd player) and sound a plenty. Is this a common prob? Guessing the processor is different and it's made of gold. Thanks |
Platinum Member Username: Nuck
Post Number: 10059 Registered: Dec-04
| Posted on Tuesday, April 15, 2008 - 08:47 pm: |
Spud, you have to look at the manual again. The incoming signal may be digital or analog(dunno) but your reciever shaould have no issues. It is a push button answer. Push buttons. |
Post Number: 2 Registered: Apr-08
| Posted on Wednesday, April 16, 2008 - 05:01 pm: |
Hey Nuck, thanks for the reply. This problem came about after three years of problem free use. This unit automatically detects which signal is coming in and is doing this with no problem. Just producing no sound on incoming digital signal. The receiver properly detects the analog connection with the cd player and plays sound just fine. Thanks |
Bronze Member Username: Levelzero
Post Number: 19 Registered: Aug-07
| Posted on Thursday, April 17, 2008 - 04:19 pm: |
Not sure if this'll work, but have you checked your connections? Have you tried new wire? |
Post Number: 3 Registered: Apr-08
| Posted on Thursday, April 17, 2008 - 05:47 pm: |
Yeah I did, it detects the connections status immediately as always. Just doesnt seem to be processing signal to sound as the analog side does. I read on a pioneer product review that someone was trading in their Onkyo for this same problem to get a pioneer. I was just wondering how common this was with pioneer? Thanks Level Zero |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2897 Registered: Sep-04
| Posted on Friday, April 18, 2008 - 07:31 am: |
Hmm, although it's been working for three years, it's possible that somehow the system has lost its settings. I would check:- 1. The DVD player in its setup settings - ensure its digital output is switched on. 2. The receiver. If it has assignable inputs, ensure the DVD input is set to the appropriate digital input. If both of those yield no joy, one of the two is broken... Regards, Frank. |
