Home > Message Board > Home Audio > Amps > Buying amps
Author Thread: Buying amps
Username: Nvmyboom
Post Number: 314
where is the best place to buy good priced and good quality home amplifiers, im looking for an amp to power a TC Sounds 12" DVC Subwoofer 2 Ohm sub?
Relevant Product Info
Username: Wattsssup
Barrie, ON
Post Number: 238
local dealer.
Username: Nvmyboom
Post Number: 315
where on the net?/ so i can compare prices
Username: Lamcam
Stanton, Ca
Usa
Post Number: 64
local dealers
Username: Frank_abela
Berkshire
UK
Post Number: 2877
This sounds like a car audio question. I suggest you'd probably be better off asking in the Car Audio section...
Username: Flyingleaf
Well personally I will find some hot local deals. And I recommend you to have a look in music123.com I have got to know a 10% off couopon from them, maybe that can be useful to you:
http://www.dealstudio.com/searchdeals.php?deal_id=96492&ru=282
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Amps > Buying amps [ « Previous ] [ Next » ]
