Thread: Will power double using 2 amps pre-out / amp-in? |
New member Username: Falcon147
Post Number: 2 Registered: Apr-08
| Posted on Sunday, April 13, 2008 - 04:15 pm: |
Q. 1. Will I double the power using two identical amps preamp out of amp 1 out to amp in of amp 2 and preamp out of 2 to amp in of 1 without frying out everything<<<< If not do I use the amps in a crossover situation in order to double or add power? Are there any other simple otions. Wayne |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12437 Registered: May-04
| Posted on Sunday, April 13, 2008 - 11:40 pm: |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 843 Registered: Feb-07
| Posted on Monday, April 14, 2008 - 08:14 pm: |
Not sure I understand the question. Why not just buy one amp that has sufficient power? How much power ya figure you need anyway? |
Post Number: 3 Registered: Apr-08
| Posted on Monday, April 14, 2008 - 09:46 pm: |
First, I am not real sharp on the preamp stuff. 400 watts would be great. I have 2 two hundred watt amps same model @ 100 watts per chan ea. both have pre out and amp in. Is this applicable re: my first Q. ? Is there a better application to use these connections? I am running everything through a 12 chanl mixer. |
