Thread: PSB problem |
Bronze Member Username: Drumsuck
St. johns,
Newfoundland
Post Number: 12 Registered: May-04
| Posted on Saturday, June 05, 2004 - 07:21 pm: |
One of my PSB Alpha's is sounding muffled for some unknown reason. The problem is definately in the speaker itself, as I tried everything else, and switched the speaker to the other channel. One speaker produces clear, crisp ringing highs, but the other sounds muffled and muddy. I've tried phasing, too. |
J. Vigne Unregistered guest |
| Posted on Saturday, June 05, 2004 - 10:39 pm: |
You've blown out the tweeter. How loud where you playing before you noticed this "problem"? |
St. johns,
Newfoundland
Post Number: 13 Registered: May-04
| Posted on Sunday, June 06, 2004 - 05:08 pm: |
About average volume for me, which is only ever about 50 - 75% up my volume dial. My HK is only rated at 80w, and the PSB's are supposed to handle 90 I think. The HK is 8ohm rated and the PSB's nominal impedance is 6. Is that a possible problem? Future Shop said that the HK 3380 is 6 ohm capable. |
Bronze Member Username: Rickypearson
Post Number: 16 Registered: May-04
| Posted on Friday, June 18, 2004 - 12:50 am: |
They will tell you what they can to make them look good, Depending on the Model and how old it is but if your HK recevier Is 8 Ohm min Capabilitie and you put in something with a 6 Ohm Capabilitie then yes that would be grounds for the Tweeter to Blow because the Reciver things its pushing 8 Ohm in to an 8 Ohm Speaker but its not and over time its gets to be to much and something has to give Hope this helps, Any other Questions Email me Rickypearson@shaw.ca |
