Home > Message Board > Home Audio > Receivers > Looking for some guidance
Author Thread: Looking for some guidance
Username: Ipmcg
Union, NJ
United States
Hello all and thank you for taking the time to read this. I have a client that is looking to do the following. Install a sound system that will support the following: DVD - video split to three projectors, Audio going to three separate parts of the building as well as possibly playing 2/3 different audio sources.
I have an idea on the receiver as well as I know I will need a multi switch. Speakers were/are going to be OB for the bigger areas and smaller tweeters for the 2 other areas.
Just wanted to get some feedback from the experts.
Thanks again for your time.
-b
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 12427
What are you asking?
Does "OB" stand for open baffle? And you're only going to use tweeters for some areas?
Username: Ipmcg
Union, NJ
United States
I am asking for recommendations for receiver as well as speaker solutions.
Yes OB as I understand will stand for open baffle.
Tweeters would be used for the smalller isolated TV's (2)
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Receivers > Looking for some guidance [ « Previous ] [ Next » ]
