Thread: Help deciding on $400-$500 Subwoofer |
Bronze Member Username: Audiobuff
Post Number: 83 Registered: Jan-07
| Posted on Sunday, April 06, 2008 - 10:50 pm: |
Hi guys, Right now my research points to these: 1. Outlaw LFM-1 Plus (Heard HSU makes these for Outlaw?). 2. Dayton HSU12 3. Elemental Designs A3-300 4. HSU VTF-2 MK 3 Im looking for something that will shake the house during movies, mainly higher DB's at lower Hertz. Some music listening as well, most likely will turn off the sub for that, unless I like the sound. Out of those subs, which one provides the most performance for the $$? If you have any that you recommend, please feel free to post! Just to give you an idea, my old sub was a JBLS120Pii. Thanks! |
Relevant Product Info
Platinum Member Username: Nuck
Post Number: 10020 Registered: Dec-04
| Posted on Monday, April 07, 2008 - 08:03 pm: |
Buff, the Hsu is a no-brainer...which is where I come in. It's a winner all around. |
Post Number: 84 Registered: Jan-07
| Posted on Monday, April 07, 2008 - 10:28 pm: |
Hi Nuck, I actually went with the outlaw, from what I gather, it was partially designed by Hsu, and a conclusion I came to was that it would be comparable to the VTF-3 (ie. for $300 less, I would never notice the difference). Im so pumped on getting this, I would imagine it will kick that pants off my old JBL S120Pii! O yeah, and my room is roughly 1920 Cubes with an adjoint dining room that is 1000. This sub should still provide "room shaking" bass if im not mistaken. |
Gold Member Username: Arande2
Rattle your ...
Missouri
Post Number: 2817 Registered: Dec-06
| Posted on Wednesday, April 09, 2008 - 01:31 am: |
Have fun with it! |
