Thread: Technics SL-J3 Speed Problem |
Manglecat Unregistered guest |
| Posted on Wednesday, June 02, 2004 - 01:54 pm: |
I have a "Technics SL-J3" "Direct Drive Automatic Turntable System" (or something along those lines). When i switch it on and press play, it starts spinning, but then just keeps on getting faster and faster. I know it's quite an old system, but i wondered if anybody else has had the same problem, or just knows why??? Any help would be much appreciated. |
| Posted on Thursday, June 03, 2004 - 12:51 pm: |
Anyone? |
| Posted on Saturday, September 11, 2004 - 11:51 am: |
Yes, replace C208 on the motor PCB If you check it prior to replacing you should find it shorted |
| Posted on Thursday, December 16, 2004 - 11:47 pm: |
Is there a proper way to lubricate the linear tone arm tracking? Mine could definitely use it, it slogs down near the rest position. |
