Home > Message Board > Home Audio > Subwoofers > Need some help
Author Thread: Need some help
Username: Nvmyboom
Post Number: 310
Im new to this home theatre stuff so i need a little help. I want to power a sub or two, like a elemental designs sub or a cvr, (12"), or suggested ones, in my dorm room. wat would be some ideas, or wat would i need to do this.
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 12392
An amplifier, a source and a volume control between them. You'll probably want some other speakers too.
Username: Nuck
Post Number: 9948
And some wires and stuff.
Username: Nvmyboom
Post Number: 311
wow thanks, i would have never guessed i would of needed wires. this whole time i thought i was going to use a wireless router to run my speakers, thanks
Username: Nuck
Post Number: 9953
Boomer, add sommore info and we will try to help.
A pic is worth
1000 posts!!
Post Number: 15431
Build a box using the manufacturers specs, tune a tad lower. Get a plate amp from partsexpress or the like to match the sub. In a dorm room you should be fine using a 10" or so. Watch the ohm load between your amp and sub and be sure not to drown out the other frequencies in the system. Connect your receiver to the plate amp using the sub out line and set all amp parameters accordingly.
Username: Nvmyboom
Post Number: 312
thanks paul, if do build a box, how much lower should i tune it to than whats recomended?
Is there a subwoofer you would recomend for indor use?
Username: Nvmyboom
Post Number: 313
Is there a subwoofer you }would recomend for indoor use?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Subwoofers > Need some help [ « Previous ] [ Next » ]
