Thread: Looking for a cartridge recommendation, please |
New member Username: Menthol22
Post Number: 1 Registered: Mar-08
| Posted on Sunday, March 23, 2008 - 06:48 pm: |
Hi, I just bought an Audio-Technica AT-PL120 turntable so I can digitize some of my old vinyl, and I'm looking to upgrade the cartridge that shipped with it. I'd like to spend under $100 if possible, as I just can't justify an expensive super high-end cartridge. In the past I have used Stantons and have been pleased with them - in fact, I have a (pretty worn out) 981S in my current turntable, a Technics SL-1800. Stanton doesn't make the 981 anymore, but I noticed that an outfit called LP Gear has a replacement stylus for the 981 cartridge. Does anyone know if this is of the original 981 quality? Alternatively, I'm considering the Shure M97xE, which seems like a reliable choice. I listen to all kinds of music - rock, punk, jazz, electronic, classical, etc. Specifically, I guess I'm asking for opinions as to whether I should get the Shure, buy the LP Gear replacement stylus, or consider something else, like an Ortofon perhaps. Oh, and is anyone interested in my SL-1800? Thx. |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12373 Registered: May-04
| Posted on Sunday, March 23, 2008 - 09:14 pm: |
. Call and ask if the Stanton replacement stylus is made by Stanton. Most likely it is. It would be my choice over the Shure. |
Post Number: 2 Registered: Mar-08
| Posted on Monday, March 24, 2008 - 06:23 pm: |
Thanks, Jan. It turns out it's not Stanton-manufactured, so I think I may take a pass. |
