Home > Message Board > Home Audio > Receivers > BEST RECEIVER FOR UNDER US$ 1000
Author Thread: BEST RECEIVER FOR UNDER US$ 1000
Username: Gosse
Guayaquil, Guayas
Ecuador
Hi everyone:
I am looking to buy a new receiver to upgrade my home theater using HDMI inputs/outputs. I have budget of $ 1000.
I am looking at the following options: SONY ES-STRDA3300ES, ONKYO TX-SR805 and YAMAHA RX-V861VL; which of those receivers do you think is the best overall option and why?? What other receive do you think I should consider for under $ 1000??
I will upgrade most of my other equipment in the near future (except the speakers which cost me US$ 4,000 for a complete Definitive Technologies 5.1 set), but my first step is to choose a best possible receiver for my budget.
Thanks in advance for your kind help.
Relevant Product Info
Username: Shawnharman
Post Number: 187
you should look into harman kardon and nad also
Username: Nickelbut10
Post Number: 1292
NAD and Onkyo would be my two first picks for under a grand.
Username: Artk
Albany, Oregon
Post Number: 6574
For movies I like the Yamaha RX V series. Not really honest power specs but considerably more reliable (service) than NAD, Marantz and Denon. Onkyo used to be awful but I understand they have made some changes.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12369
Is this a stereo or multichannel receiver?
Username: Artk
Albany, Oregon
Post Number: 6576
Appears to be multichannel, or at least that's what he's listing. He also has a full set of Def Tech HT speakers.
Post Number: 1294
Cambridge Audio have some fairly nice sounding A/V receivers for under a grand as well. Worth an audition.
Username: Gosse
Guayaquil, Guayas
Ecuador
Post Number: 7
Thanks a lot to everybody for your comments and recomendations.
Yes, receiver must be a multichannel and I will be buying a blu ray player that is why I am upgrading my old receiver that does not have HDMI inputs.
Can you recommend especific brand and model numbers so I can check them out?
Username: Gosse
Guayaquil, Guayas
Ecuador
Post Number: 8
Also is very important that the receiver will have all the latest technologies so it could handle most of the newer equipments.
Username: Gosse
Guayaquil, Guayas
Ecuador
Post Number: 9
In other words, if you have the US$ 1000 to spend for a home theater receiver; which one would you buy....and why.
Thank you again for your kind help
Username: Artk
Albany, Oregon
Post Number: 6577
Easy enough to use a search engine to look up brands and find the models. Then check on prices the same way. You had models already listed...start with those.
Username: Frank_abela
Berkshire
UK
Post Number: 2794
I have played a lot with the Onkyo TX-SR605 and a bit with the TX-SR875. The 875 uses the same DSP chipsets as the 805 but has a better video processing and an extra HDMI input.
These are very good receivers offering very good value for money (even better in the US). They are as future-proof as it gets at the moment, offering all the codecs required to support Blu-ray. The only limitation is downscaling. I do not believe they can take a 1080p HDMI input and downscale to component or s-video for example, but the passthrough works very well, giving us spectacular results using a PS3 into a Panasonic PTAE2000E projector onto a 7' screen.
Incidentally, at the moment, the PS3 looks like the best Blu-ray player value for money. The Panasonic BD30 is meant to be a royally good player too although I'm not sure if it has the networking capability of the PS3, which guarantees future upgrades.
Regards,
Frank.
Username: Gosse
Guayaquil, Guayas
Ecuador
Post Number: 10
Hi to everyone and thank you for all your comments.
After doing an extensive research I think I will choose the DENON AVR-2808CI which is being sold by Amazon at US$ 999. Do you think I am making a good decision???
Username: Artk
Albany, Oregon
Post Number: 6589
I prefer Yamaha to Denon and believe that Onkyo is now superior to Denon. Denon's user interface has always been clumsy and I have no resaon to believe that has changed...spoke with an installer last week who confirmed that. However since you're going to be using it it's important that you like it.
Username: Gosse
Guayaquil, Guayas
Ecuador
Post Number: 11
Thanks for your comments. Previously I was considering an Onkyo but I have read in several blogs that there are some serious quality issues with regards to the latest Onkyo models. Why do you prefer Yamaha??? Better sound that the Denon or it is more features??
Username: Dmitchell
Ottawa, Ontario
Post Number: 765
Take Sony off the list. I like Pioneer and Yamaha. Not sure how much the entry level Elite is these days, though.
Username: Artk
Albany, Oregon
Post Number: 6590
I like the Yamaha user interface and the RX-V model that I have (657 from a couple of years ago I think...too tired to go and look, you can check my profile it's there) is actually quite good for movies. I don't listen to music with it...but it's actually very good for movies and concert video's. Keep in mind that I mean for a mass market receiver it has done very well for me. In fact it's the component with the longest lfe in my home at the present (primarily because I don't wan't to spend alot of money on HT gear).
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Receivers > BEST RECEIVER FOR UNDER US$ 1000 [ « Previous ] [ Next » ]
