Home > Message Board > Home Audio > Preamps > Integrated amp with a pre amp
Author Thread: Integrated amp with a pre amp
Username: Roddyboy
Woodbridge, Va
Us
Hello, i was thinking of buying a preamp with HDMI connections and using it with my NAD372. Is this possible? and is it worth it? Would i get true 5.1/7.1 sound?
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 12348
What pre amp has HDMI connections? I don't see how you could expect 5.1 channels from a two channel amplifier.
Username: Roddyboy
Woodbridge, Va
Us
Keeping my NAD372, what would you suggest as an add on so that i can have HDMI connections to play my SACD, DVD-A, etc?
Username: Roddyboy
Woodbridge, Va
Us
Post Number: 7
Keeping my NAD372, what would you suggest as an add on for HDMI connections for my SACD player, DVD, etc?
Username: Nickelbut10
Post Number: 1279
You can't add HDMI to a 372.
Username: Roddyboy
Woodbridge, Va
Us
Post Number: 8
Before i just totally drop this subject NAD makes a T 175 Preamp-tuner/Processor with HDMI connections. Couldn't I use this vs having to buy a new amplifier?
Dallas, TX
Post Number: 12351
I would suggest you contact a NAD dealer in your area. Listen to any product before shelling out money for something that means very little. Why do you want HDMI? Run your video cables directly to the monitor and your audio cables into your existing unit. HDMI connections are intended to replace multiple cables but they are not necesssarily going to provide better quality. You will spend less money on a second set of cables than you will on a pre amp just to gain HDMI. If you only have a two channel amplifier, you still will not gain 5.1 surround functions by adding HDMI inputs to your pre amp section. Go talk to a dealer and get a bit of an education into how all of this works.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Preamps > Integrated amp with a pre amp [ « Previous ] [ Next » ]
