Thread: Digital out connector to RCA input |
New member Username: Roddyboy
Woodbridge,
Va
Us
Post Number: 2 Registered: Mar-08
| Posted on Wednesday, March 05, 2008 - 08:51 pm: |
Is it possible to use my SACD digital out (coaxial), and using a splitter, go to the back of my integrated amp (NAD 372)that only has RCA plugs? What kind of sound should i expect? |
Relevant Product Info
Gold Member Username: Nuck
Post Number: 9855 Registered: Dec-04
| Posted on Wednesday, March 05, 2008 - 08:58 pm: |
nope. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2761 Registered: Sep-04
| Posted on Friday, March 07, 2008 - 09:38 am: |
Rodney, For goodness sake don't do this! You can damage your speakers, and possibly your amp. A digital output provides a digital signal. This is of vaguely the same strength (voltage range) as analogue signals but its shape is distinctly different and can cause the amp to dump large amounts of current into the speakers. I strongly recommend you don't do it. Regards, Frank. |
