Home > Message Board > Home Audio > MP3 and Digital Audio Players > Rca lyra 1076b won't work HELP Please...
Author Thread: Rca lyra 1076b won't work HELP Please
Username: Nikiwi
I have had problems for a long time w/ getting it to
a. transfer files w/o the sd card being write protected.
b. 50% of the time or more it will only play for about 5 seconds with a new battery and then turn off
c. I did drop it in some water once and tried to dry it, but I guess it messed up the hard drive.
It was after that, the SD card was working part of the time. I have checked and it's not locked or anything. HELP PLEASE!!!1
Username: Project6
Post Number: 15705
"I did drop it in some water once and tried to dry it"
DUH!
Water and electronics do not mix. Replace your player with a new one.
If your issue is with the SD card being write protected, did you check the write protect tab?
And...replace the player.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > MP3 and Digital Audio Players > Rca lyra 1076b won't work HELP Please... [ « Previous ] [ Next » ]
