Home > Message Board > Home Audio > Subwoofers > The most boom for 175$
Author Thread: The most boom for 175$
Username: Crazyloof
Any suggestions are the subwoofer that would give me the most bass for 175$... suggestions only please none of that "well for 250$ you can get something uber leet".
Relevant Product Info
Username: Artk
Albany, Oregon
Post Number: 6452
Buy used....check Audiogon and Videogon.
BTW that is a suggestion.
Username: Crazyloof
Does anyone have a specific subwoofer in that range though?
Username: Artk
Albany, Oregon
Post Number: 6453
Check the resources mentioned like Agon and Vgon and ask questions relative to specific product that happens to be available...for instance a Martin Logan Dynamo might be for sale near your budget if so then ask about it specifically. I think it's pretty much a consensus here that there isn't anything worth buying in your price range new, so we have to know what you're looking at used to give an informed response.
Username: Artk
Albany, Oregon
Post Number: 6454
http://www.audioadvisor.com/prodinfo.asp?number=ATASP4100B
Username: Crazyloof
Went ahead and bought a Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer after reading about it quiet a bit.
Username: Artk
Albany, Oregon
Post Number: 6455
Good luck...
Username: Dmitchell
Ottawa, Ontario
Post Number: 696
Sony are not known for their subwoofers. Or for audio gear in general.
Username: Nuck
Post Number: 9851
Alas poor l t, I knew him well.
Now suffering the slings and arrows of outrageous audio misfortune and rambunctious purchase.
Isn't that a Sony ad?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Subwoofers > The most boom for 175$ [ « Previous ] [ Next » ]
