Thread: Loss of 33 RPM on Technics SL-23 |
New member Username: God_is_american
Post Number: 1 Registered: Mar-08
| Posted on Sunday, March 02, 2008 - 08:05 pm: |
Hi guys, I've been reading another forum post with information about the SL-23 but didn't find anyone with my problem. I scored the SL-23 from my grandparents yesterday, probably hasn't been used in 15 years. It worked fine for the first day but then this morning whilst playing it jumped up to a much higher speed, I guess it's 45 but I don't have any 45s to check. It seems to play the same speed whether the switch is on 33 or 45. Does anyone know what could be causing the problem? I have some experience with electronics and I am going to try replacing the pots today as was suggested for a different problem in the other post. |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12331 Registered: May-04
| Posted on Sunday, March 02, 2008 - 08:19 pm: |
. Whenever a component has been sitting for a length of time it should never be plugged into a wall outlet and hit with 120 Volts. The best way to bring a component up to working voltage is with a controlled voltage device such as a Variac. You've probably damaged a component in the speed control section of the table, most likely a capacitor. I have no idea which one it would be on this table and a failed capacitor can take out other components in front and behind itself. . |
Post Number: 2 Registered: Mar-08
| Posted on Sunday, March 02, 2008 - 08:28 pm: |
OK, thanks, I'll see if I can see any damaged caps. Also, I'm in Australia so it's 240 Volts @ 50 Hz |
