Thread: Rega planar 2 main bearing question |
New member Username: Tama4514
Post Number: 1 Registered: Feb-08
| Posted on Saturday, February 23, 2008 - 07:32 am: |
I just purchased my first TT (a rega planar 2) on ebay. On setup I found that the sub platter is sitting lower than the belt drive. Consequently the glass platter is resting on the belt drive. This doesn't seem right to me. Can someone please tell me more about this? |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12304 Registered: May-04
| Posted on Saturday, February 23, 2008 - 09:58 am: |
. Check for a small ball bearing in the bottom of the table's main bearing shaft. Quite often this can get lost is shipping or set up. |
Post Number: 2 Registered: Feb-08
| Posted on Saturday, February 23, 2008 - 06:52 pm: |
Thankyou mate, you are right, I cannot see the small ball bearing! So am I able to get this ball bearing and put it in myself, or should I have someone who knows what they are doing look at it? |
Gold Member Username: Nuck
Post Number: 9820 Registered: Dec-04
| Posted on Saturday, February 23, 2008 - 07:01 pm: |
You want the proper ball bearing, Tama, lubricated and drop it right in! |
Post Number: 3 Registered: Feb-08
| Posted on Saturday, February 23, 2008 - 07:22 pm: |
Sweet as! |
Post Number: 9821 Registered: Dec-04
| Posted on Sunday, February 24, 2008 - 06:31 am: |
yep! |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2747 Registered: Sep-04
| Posted on Wednesday, February 27, 2008 - 07:49 am: |
You can get a new bearing from rega or their dealers. Ensure you use the correct oil. I seem to remember Rega mention which type and how much to use on their website. |
