Home > Message Board > Home Audio > Receivers > Archive through March 05, 2008 > Receiver for wharfedale diamond 8.3
Author Thread: Receiver for wharfedale diamond 8.3
Username: Mark_lapin
Hi everyone,
I am looking for an entry-level receiver for my Wharfedale Diamond 8.3s. So far the options are Yamaha 559 and Harman/Kardon 137. However, I am not sure the 8 ohm HK can properly handle the 6 ohm Wharfedales. Any opinions?
Relevant Product Info
Username: Exerciseguy
Brooklyn, NY
United States
Post Number: 1826
If you your only running the 8.3 why are you considering surround receivers?
If want to go the 2-CH route, the HK3485/HK3385, the NAD 720BEE, and the Outlaw RR2150 are all good contenders.
Christopher: Because one day I am going to buy a sub and (maybe) everything else.
Username: Nuck
Post Number: 9815
A sub works fine with stereo applications.
Brooklyn, NY
United States
Post Number: 1827
oh.
I am going to use it for both music and cinema, so it would be nice to have some video connectivity.
Brooklyn, NY
United States
Post Number: 1828
Most new 2-CH receivers have some video connectivity, but if you want to plan for a surround sound future, then you should go that route.
What's your budget?
Around $400.
Surround is not really a necessity. If I could find a Wharfedale-capable stereo receiver with component video inputs and outputs, a subwoofer output and maybe a couple of hdmi ports, it would be great. But what's wrong with a 5.1 box? Does it really sound much worse than a stereo one? (Sorry if that's a stupid proposition :-)
Brooklyn, NY
United States
Post Number: 1829
If $400 is the budget, the Marantz SR5001 (factory refurb)
http://www.accessories4less.com/make-a-store/item/MARSR5001/MARANTZ/SR5001-XM-Re ady-Surround-Sound-Receiver/1.html
http://www.ubid.com/Marantz_SR5001_630W_7.1_Ch._A%2fV_Home_Theater_Receiver/a112 42061-rsearchone.html
is about as good as you could do. It's been my experience that Marantz surround receivers excel at 2-CH audio.
Christopher,
Thank you for the advice. This Marantz sure looks good. Unfortunately, here in Russia it goes for a minimum of $915, which is way beyond the budget.
Brooklyn, NY
United States
Post Number: 1830
Russia?!?
That's way out of my jurisdiction, good luck.
Username: Nuck
Post Number: 9819
Gawd, there must be huge black market deals going on there!
Username: Nickelbut10
Post Number: 1221
In your price range look at some entry level Pioneer or Yamaha receivers.
Home > Message Board > Home Audio > Receivers > Archive through March 05, 2008 > Receiver for wharfedale diamond 8.3 [ « Previous ] [ Next » ]
