Thread: Component Video / Bandwidth |
Bronze Member Username: Klaussner
Post Number: 25 Registered: Jul-05
| Posted on Monday, February 04, 2008 - 09:06 pm: |
Is less than 100mhz a big deal? Anything below the 805 model for Onkyo has 50mhz |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12231 Registered: May-04
| Posted on Monday, February 04, 2008 - 09:34 pm: |
. The only on paper specs you need to look at are; height, width, depth and weight. |
Gold Member Username: Nickelbut10
Post Number: 1115 Registered: Jun-07
| Posted on Monday, February 04, 2008 - 10:39 pm: |
huh? Brian...run your video to your tv. Run your audio to the receiver. Don't worry about specs, plug it in, if you have video..u win. Cheers. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 624 Registered: Feb-07
| Posted on Tuesday, February 05, 2008 - 09:13 am: |
Always keep video and audio separate. Component cables (or HDMI) should run from your set top box (cable or satellite) to your TV, and analogue cables (RCA) to your receiver. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2693 Registered: Sep-04
| Posted on Tuesday, February 05, 2008 - 09:53 am: |
Heh, but HDMI is both audio and video. Furthermore, if you wish to take advantage of the uncompressed tracks of HD-DVD or Bluray, you MUST use the HDMI connection since the audio stream has to be encrypted in transit. |
Ottawa,
Ontario
Post Number: 625 Registered: Feb-07
| Posted on Tuesday, February 05, 2008 - 09:56 am: |
True Frank, but how many people currently have a receiver that is capable of decoding TrueHD and DTS-HD? |
