Thread: Audioquest Alpha snake and Kimber Kable PBJ |
Bronze Member Username: Lamcam
Stanton,
Ca
Usa
Post Number: 26 Registered: Nov-07
| Posted on Monday, February 04, 2008 - 04:19 pm: |
Hi all, I have been using cheap entry level AQ Alpha Snake with my Rega Plannet, Rega Brio Int. amp, 12 gauge HD speaker cable, and Dyn A42 speakers. The sound quality was good, warm, and detail. I decided to try something new, so I bought the KK PBJ interconnect to try out. The sound is more detail, but hurt my ear, the warm sound was disappear, the bass was reduced. Do you think I should stay with the AQ brand, but move up to more expensive cable, and what do you recommend? Or should I try a more expensive KK brand? Thanks. |
Relevant Product Info
Silver Member Username: Hawkbilly
Nova Scotia
Post Number: 127 Registered: Jul-07
| Posted on Monday, February 04, 2008 - 05:03 pm: |
My experience with PBJ's is that they are pretty benign as a cable. They certainly weren't brighter than the cables I replaced with them, but obviously the results may vary on different systems. I wonder if the PBJ's are just feeding you what is coming from your source, and your old cable was just warming it up so you didn't notice until now. Just a thought. Don't worry about what you think you should or shouldn't do....just go with what sounds best to you. If the PBJ's aren't your thing, switch back or try something else. |
Stanton,
Ca
Usa
Post Number: 27 Registered: Nov-07
| Posted on Monday, February 04, 2008 - 05:23 pm: |
Thanks for replying! Like all other music lovers here, I'd like to try ways to make my system sounds best. |
