Home > Message Board > Home Audio > Receivers > Archive through March 05, 2008 > Yamaha RX-V2300 Receiver stop playing
Author Thread: Yamaha RX-V2300 Receiver stop playing
Username: Johnjd
United States
Hello to One & All,
I am new here. I was rocking out Last night. When out of the blue my Yamaha RX-V2300 Receiver quit playing. It is 3 yrs old .I have never had a problem before. I was at 3/4 vol and it was there for about 4 hrs. From what I have read on this site it seems the people here know what they are talking about. What can I do? I do not see a fuse or reset.
Thanks John
Username: Jan_b_vigne
Dallas, TX
Post Number: 12214
You probably broke it. 3/4 volume for four hours is not really what this amplifier was meant to do.
Unplug the receiver from the wall outlet for about an hour. If it resets, you're in business.
Otherwise, if there's no external fuse, you aren't meant to do any service on the receiver. You should take it to a service center, if there's a simple fix - an internal fuse - they'll probably replace it at little to no cost to you.
Username: Johnjd
United States
Thanks Jan,
I will try what you said and unplug it. I will let you all know how that went.
Thanks John
Username: Johnjd
United States
I broke it!!!
Username: Jaw
Post Number: 179
It's only been 1:04; you run a tight schedule.
Take out the screws, open up the case and see if there are some fuses in clips; push them up with a pencil or plastic spoon and see if they're blown. Be careful, some electricity could still be stored inside.
If the fuses are OK, let is sit for 24 hours uplugged; then you broke it.
Username: Johnjd
United States
Jaw, lol I will do it now.
Username: Johnjd
United States
There is only one fuse. It looks good. I will check in 24hrs.
Be cool
John
Home > Message Board > Home Audio > Receivers > Archive through March 05, 2008 > Yamaha RX-V2300 Receiver stop playing [ « Previous ] [ Next » ]
