Home > Message Board > Home Audio > CD Players > Cambridge Audio 640C
Author Thread: Cambridge Audio 640C
Username: Dmitchell
Ottawa, Ontario
Post Number: 587
So now that I have these really nice speakers (MA RS6) I've decided that I want a half-decent CDP to complement them.
I was at a local audioshop where the sales guy showed me the various options in my price range, and suggested the Cambridge Audio line. I did a listening test on the 640C and the next model down in the line (can't remember the model number). There was actually a noticeable difference in SQ quality between two. The 640C seemed to handle the piano better (more pronounced), cymbals were more precise and vocals seemed to have a bit more depth.
The thing I liked about the 640C is that it has dual DACs. Probably worth the extra 200 bucks.
So my question is, do any of you guys out there have one of these? If so, how do you like it?
Thanks.
Relevant Product Info
Username: Darrenmc
Winnipeg, Manitoba
Post Number: 49
Hey David(fellow CDN!), I have the exact same speakers as you. I had the RS1's and exchanged them for the RS6's, difference was huge for me. I just love floorstanders. Anyway I'm in the process of upgrading my source as well. I currently have a NAD C542 player which would be in the same price range as the Cambridge Audio Azur 640c, maybe a little more expensive but both budget players. The NAD C542 is a good player but I will be moving up the chain at twice the cost. I haven't heard the 640C but will be doing a home demo of the 840C(3x the price)and will let you know what I think. What is your budget for a player?
Username: Artk
Albany, Oregon
Post Number: 6072
Both Cambridge players are very good values...
Username: Dmitchell
Ottawa, Ontario
Post Number: 588
Hi Darren,
My budget is around $700, give or take a bit.
I had my eye on the NAD C542 as well, but I get the impression the CA is better both SQ and build quality-wise.
Username: Dmitchell
Ottawa, Ontario
Post Number: 589
And how are things in the 'Peg? I was there a few years ago in the middle of Jan.
And I thought Ottawa was damned cold...
Username: Darrenmc
Winnipeg, Manitoba
Post Number: 51
Hey David things were damn cold in the Peg this week, in the -40 to -45 range with the windchill. Never been to Ottawa but would like to visit some day. Now to the cd players, I would pick out a few cd players within your range and give them all a test run. CA makes a good product and gives great value. Also you could throw the Rotel CD-1072 into the mix, it gets high praise for it's quality and does HDCD decoding if that matters to you, although I have never personally heard it. If you could stretch a little bit then I'd say listen to the Arcam CD73T and the CA Azur 740c.
Username: Dmitchell
Ottawa, Ontario
Post Number: 590
When I was there I walked to Portage and Main, just to say that I'd been there (just like the song). I think it was around -40. I stood there for about 5 seconds.
The dealer I was at also carries Rotel CDP. I didn't have enough time to give those a listen. How would you say these compare to the CA's?
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 379
I am right now listening to a Rotel 1072 cdp. It sounds great to me on my humble budget set up. Rotel 1070 int amp and Quad 11L spkrs.
I have the Cambridge Azure 640C CD player in the bedroom, I have used it with 4 different amps and 3 different set of speakers and I have always found it musical and enjoyable...EXCEPT for quiet bedroom music.
As I have posted previously, it is noisy and not acceptable for that application. It is just that I want to keep the Rotel system together in the living room for synergy and the wife likes the looks of one matching system. It is good for higher volume, ie when the music is louder than the mechanical whirring of the Azure. It has been that way since I bought it new. I am far remote from the dealer so I chose to hope it would wear in but it has not quieted down. I
I would sell it cheap. It does not have excess wear because I have listened to 3 other cdp in the mean time, plus vinyl and FM. (Naim cdp, Rotel and Pionier cdr).
Username: Artk
Albany, Oregon
Post Number: 6099
Too bad about your Cambridge dealer being so far away. Sounds like a defective one which should be returned.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 380
Yes, I should have but I waited too long. Oh well, now I have an excuse to get an Apollo! But no hurry. Waiting for a bargain deal.
I may get a decent price for the Azure when the time comes.
Username: Artk
Albany, Oregon
Post Number: 6103
I really love my Apollo. This is really a cd player that I never tire of...though my P5 is better.
Username: Dmitchell
Ottawa, Ontario
Post Number: 599
Was reading up on the CA 640C on audioreviews.com and it seems a significant number of people have had issues with this CDP (such as channels dropping out).
Then again, I've heard the same kind of complaints about NAD CDPs...
Username: Artk
Albany, Oregon
Post Number: 6110
Yep.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 382
Well the store where I bought my CA denies having above average problems with Cambridge but it is still their 3d favorite that they sell after Naim and Rega.
I feel that the sound of the Azure640C is a good value but feel that CA could have responded to my plight even though I failed to meet the deadline for return to dealer. They never responded to my request for help nor offered no suggestions. Maybe it is a simple fix and they would know that, but I got silence from them. Poor public relations. So now I am a Rega/Rotel guy.
btw, I do agree with that dealer that Naim is great. I had a Naim cdp that sounded the best that I have owned. I sold it just because it was hard to center the weight every time, and refused some cds. I do miss that clear sound.
Username: Amitg
Ive got both the 640c as well as the NAD 542. A bit tough to say which is better sounding but id think the 640c is slightly better with more rounded bass.
However the NAD is better put together. The 640c sometimes has a problem with the power supply making a buzzing sound when its in standby mode and the open/close button seems to have a mind of its own. The 542 is 6 months older but has never had any problems.
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 148
i have had my cambridge 640C v2 for about one year.run it through cambridge 540A v1 and PSB image B25 speakers.and use it quite a bit,and have never had one problem with it.
what type of noise makes it noisy? i am not sure i have ever heard it making noise,except in transport.i have listened to quite music.
anyway i am a cambridge fan and have enjoyed my experience as my first move up into audiophile world.
Username: Dmitchell
Ottawa, Ontario
Post Number: 721
I've had mine for about 5 weeks and I've never had any issues with mechanical noise coming from mine. The only issue I had was when I first got it home the tray wouldn't open. I had to gently persuade it open, and I've never had any trouble since then.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 473
So happy to have replaced my Cambridge Azure 640C. Apollo is now my main one and Rotel in the bedroom.
Anyone want to buy a used Azure 640C cheap?
The noise from the Azure is the sound of the disc spinning, like when you open a cheap boom box while it is turning. Mechanical noise, not electronic. What bothered me was that I could never get an answer or advice from Cambridge.
On their website there is a forum for problems where I got no help either. So simply due to their silence I am now converted to Rega and Rotel.
Just a few words from them could have made a loyal customer.
Username: Dmitchell
Ottawa, Ontario
Post Number: 730
Sorry to hear that you had so much trouble with Cambridge, Kevin. I'm very happy with mine so far (knocking on wood...).
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 477
Thanks David. No breakdowns though, so I would call it reliable. It always worked fine.
Sounds good too.
It was my mistake to think that it would wear in and get quiet with age. I wanted to believe that because I hoped to not have to mail it away.
I think that if someone had bought it who used it in a higher volume setting would never have noticed. I did enjoy it for the loud music sometimes.
It was just that for the bedroom I need a quiet one. ECM and Windham Hill night music!
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 149
hello kevin.i am not being difficult but don't know what kind of noise you hear? i listen to a lot of minimalist classical and electronic music and hear no noise.my "rig" has been mentioned previously in this thread.
just not sure what kind of noise the CD player was making.could you explain?
Username: Hawkbilly
Nova Scotia
Post Number: 173
My own experience in this price range ($600-$800) was it was better to spend the money on a quality DAC, if you have a cdp that will function as a transport. I had been using my NAD 541i as a cdp, but it is now on transport duty. The difference with my DAC in place was the biggest single upgrade I've made to my system.
You will need to factor in the extra cable, but with the right DAC the improvement can be profound, and keep you in the same price range.
Just another option to consider.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 478
mwf- "...don't know what kind of noise you hear?"
Just the disc spinning. You must have opened a boom box, cheap portable cdp and heard the spinning disc. Only difference is that you don't have to open the drawer to hear the disc whirring around, sort of like a regular scrape.
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 150
wow! i can't say that i have heard that with my unit.will listen to some really quite music with and without headphones and let you know what i discover
Username: Dmitchell
Ottawa, Ontario
Post Number: 736
I'm listening to mine right now. I put my ear right up next to it and all I hear is a very faint whirring sound of the disc spinning. Perfectly acceptable to me.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 481
Great. I am glad that mine is the exception!
Username: Dmitchell
Ottawa, Ontario
Post Number: 740
Seems that yours was not the exception Kevin. If you take a look at some of the reviews of it on AudioReview.com, there's a bunch of people with issues:
http://www.audioreview.com/cat/digital-sources/cd-players/cambridge-audio/PRD_29 9480_1586crx.aspx
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 151
regarding the noise from the cambridge AZUR 640C v2.you mean the sound of the disc spinning when you put you ear right up to the transport area! jeez! you can't hear that unless your ear is right against it,and with music on not at all.
talk about nit picking!!!
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 490
I am talking about 640C v1 and the noise you hear while laying in bed at night that is exactly the same level as the music. The only solution is to play the music louder than the noise which means daytime only.
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 152
well maybe the V1 made a louder noise.because the noise on my unit is not noticeable with music even at minimal volume
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 491
Reading through David Mitchel's link above I noticed that many people had no problem. I did not take the time to count the % but it does look like a minority.
Then when you look at those with problems, dependability seems to be the main complaint. Mine works dependably.
Those with complaints of noise are only a few. Maybe 2 or 3 only. I did not add mine since I have posted it enough.
Also I did not pay attention to which version the problem ones were.
At this point I am past CA. Last step to sell it or give it away.
Username: Nuck
Post Number: 9914
Send it to me, KC,I will offer an opinion, hehehe.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 494
OK, it's on the way ;)
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > CD Players > Cambridge Audio 640C [ « Previous ] [ Next » ]
