Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Receiver for Cerwin Vega VS 150?
Author Thread: Receiver for Cerwin Vega VS 150?
Username: Chrischin478
I am looking for a 2-Channel 300 watts RMS/Channel receiver under $300 to power some Cerwin Vega VS 150's. I have looked for hours and can't find anything with these numbers. Does anyone have recommendations for what amp/receiver setup (under $300) I should use for these?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12138
"I have looked for hours and can't find anything with these numbers."
Doesn't that suggest something to you, Christian?
Why do you need 300 watts with CV's?
Username: Nuck
Post Number: 9674
They are called out at 102db!
They could be powered by a potato.
Hit the pawn shop for a decent 100w amp.
And earplugs.
Username: Wattsssup
Barrie, ON
Post Number: 201
powered by a potato....lol.
Username: Nuck
Post Number: 9676
That is Jan's, I borrowed it
So all I need is a 100w receiver to make these puppies ring? Is that RMS or Pure wattage?
Username: Nuck
Post Number: 9682
It's all the same man. Those speaker play so loud for the input, a 300w amp would just blow them up on a jag.
Look for a H/K receiver on a budget, a 3380 would do just fine.
The specs on these say the power handling is minimum 5 watts, maximum 400 watts.
Username: Nuck
Post Number: 9688
Ignore that, it is useless print on a stupid tag.
For 3 skins, shop the used receiver aisle in a stereo shop.
Or see what is at the pawn shop and do a little research online.
A100w Yamaha and a 100w macintosh are NOT the same thing.
I'm really liking the Harman/Kardon 3485. Do these specs look promising?... 120 Watts per channel, 20Hz – 20kHz @ <0.07% THD, both channels driven into 8 ohms or
150 Watts per channel, 20Hz – 20kHz @ <0.2% THD, both channels driven into 4 ohms.
Dallas, TX
Post Number: 12141
That receiver should drive the CV's to a very high level of volume in the average size room. If you require more power than that receiver supplies in the real world, you will need to look at a separate power amplifier and increase your budget five fold.
Buy the HK.
Thanks for all the input
Username: Nuck
Post Number: 9695
Yep. The HK and the CV's are a match made in college budget heaven.
Now feed the thing with a good source.Full sized files from a pc.
Dallas, TX
Post Number: 12152
Blackwalls or raised white lette ... oh, files!
Username: Nuck
Post Number: 9701
Vigne, you really should wash the windows or something.
Or send me an
EMAIL!
Username: Fullertonbusiness
If you really want to pump up the volume with a 100 watt per channel receiver, you will need to buy a nice subwoofer with a low crossover frequency (80 for THX, <50 for other)
Home > Message Board > Home Audio > Receivers > Archive through September 07, 2008 > Receiver for Cerwin Vega VS 150? [ « Previous ] [ Next » ]
