Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Rest TV on top of Center Speaker?
Author Thread: Rest TV on top of Center Speaker?
Username: Billru44
Post Number: 38
Hey,
I just picked up the Infinity PC350 center speaker and this thing is pretty big. Turns out i don't really have a place for it. So, I figure i can rest my Sony Bravia 42in LCD TV (on the mount) on top of the speaker. Do you think this could damage the speaker?
It's resting on top of the speaker now and seems to be fine. The speaker is large enough that there is enough room for the base of the LCD TV stand. (The TV is probably about 50 lbs)
Username: Dmitchell
Ottawa, Ontario
Post Number: 562
I've heard of some people doing this with the v5 Paradigm center channels (which are ridiculously large).
Never tried it myself.
Username: Exerciseguy
Brooklyn, NY
United States
Post Number: 1765
Do you have a choice Bill?
Username: Dmitchell
Ottawa, Ontario
Post Number: 563
At least LCD's are relatively light, compared to Plasmas.
Username: Billru44
Post Number: 39
Nope, no choice of anywhere else it could go.
Brooklyn, NY
United States
Post Number: 1766
Well there you go.
Username: Nuck
Post Number: 9654
Placing the display on top of anything other than a balanced stand which support the mass of the display cabinet either on it's
a: intended solid center mount,including the entire area of the flat pedestal provided, or
b:an appropriate wall mount frame,
will subject the unit to unnecessary vibration, flexure and stress.
Username: Artk
Albany, Oregon
Post Number: 6032
Yep, seems as though the vibration would not be a good thing...not sure but that seems common sense.
Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Rest TV on top of Center Speaker? [ « Previous ] [ Next » ]
