Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Problems with fuse?
Author Thread: Problems with fuse?
Username: Stamant
LA, FL
Post Number: 346
I have a JBL TLX PS12 sub. The power light is not coming on. I replaced the fuse. The light for power goes green for about 3-5 seconds and then the fuse blows. Any ideas why?
Username: Ccdoggy
Post Number: 185
the amp is blown and is shorting out internally. Its dead, sorry.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12118
Do not poke around inside this amplifier. There are lethal Voltages in this amp that can easily cause more problems than you already have.
Is the sub in warranty? If so, take it to a repair center. If not, determine whether you want to repair this amplifier. If so, you have several options. You can buy a new plate amplifier or you can get this one repaired.
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Problems with fuse? [ « Previous ] [ Next » ]
