Thread: Totoem Sttaf's on marble tile |
Bronze Member Username: Smwick
B.C
Post Number: 15 Registered: Dec-07
| Posted on Friday, January 11, 2008 - 12:36 am: |
I'm experimenting with the Totems sitting on 1/2" marble tiles in a carpeted room. I removed the spikes from the base of the speakers and put tiny rubber bumpers in place of the spikes. Aside from looking more exotic, I think they sound a little better. Base seems a little tighter and the over all sound is cleaner. Am I just imagining this or does this reduce vibrations and help clean up the audio. I also have them mass loaded, but that was done earlier. Any thoughts on this? |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 5915 Registered: Feb-05
| Posted on Friday, January 11, 2008 - 02:02 am: |
Enjoy! |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12024 Registered: May-04
| Posted on Friday, January 11, 2008 - 11:31 am: |
. "Base seems a little tighter and the over all sound is cleaner." Hey! Sounds like you've made it to second base. |
B.C
Post Number: 16 Registered: Dec-07
| Posted on Friday, January 11, 2008 - 12:42 pm: |
"Hey! Sounds like you've made it to second base." lol, Jan thats pretty good on the spelling error. |
Gold Member Username: Mike3
Wylie,
Tx
Post Number: 1018 Registered: May-06
| Posted on Friday, January 11, 2008 - 11:32 pm: |
Steve, Anything you change, anything, can have an impact on your sound. Sometimes it seems better, sometimes it seems worse, sometimes it seems.......... changed. Lots of ways to tweak and experiment. That is one of the joys of this passion of ours. |
