Thread: Oyaide R1 AC outlets......BEST UPGRADE! |
Silver Member Username: Hifisoundguy
Post Number: 194 Registered: Aug-06
| Posted on Thursday, January 10, 2008 - 06:47 pm: |
If you are looking for the best upgrade in your system then just try one of these Oyaide R1 ac outlets! The place I got mine they stay out of stock all the time...it takes a while to get them www.cryo-parts.com/oyaiderec.html Do a GOOGLE search for...(Oyaide R1 forums)....lots of good stuff on these outlets there! |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 526 Registered: Feb-07
| Posted on Thursday, January 10, 2008 - 07:07 pm: |
I thought the other thing was the BEST? |
Post Number: 195 Registered: Aug-06
| Posted on Thursday, January 10, 2008 - 11:47 pm: |
The Crystal Clear is the best contact enhancer that I have used....these outlets..WOW! the BEST $130 YOU WILL EVER SPEND!.............. |
Silver Member Username: Nickelbut10
Post Number: 992 Registered: Jun-07
| Posted on Friday, January 11, 2008 - 12:24 am: |
Randy..are you some virus? You remind me of a spam email..you know the ones that send you all those viagra emails to your work email, and all of it is the "Best". Randy can you post something about what you feel is the BEST cd out there today, or what kind of music, you think is the "best". I would rather hear that, then some stupid tweak. |
Gold Member Username: Nuck
Post Number: 9561 Registered: Dec-04
| Posted on Friday, January 11, 2008 - 05:00 am: |
The Clear...hmmm...ism't that what Barry Bonds used? It must enhance something. |
Silver Member Username: Nmytree
Post Number: 161 Registered: Aug-04
| Posted on Friday, January 11, 2008 - 01:21 pm: |
Hospital Grade Orange outlet, $10.00 at Lowes or Home Depot. They work just as well and look groovy in orange  |
Post Number: 162 Registered: Aug-04
| Posted on Friday, January 11, 2008 - 01:22 pm: |
http://electrical.hardwarestore.com/14-53-double-outlets/ground-hospital-duplex- receptacle-671437.aspx?CAWELAID=42559931 |
Post Number: 163 Registered: Aug-04
| Posted on Friday, January 11, 2008 - 01:23 pm: |
http://electrical.hardwarestore.com/14-53-double-outlets/hospital-duplex-outlet- 620298.aspx |
