Thread: Infinity Beta Center with Primus Fronts? |
Bronze Member Username: Billru44
Post Number: 23 Registered: Jan-05
| Posted on Wednesday, January 09, 2008 - 06:53 pm: |
Hey I have the Infinity Primus 362 fronts. If I were to get a center channel from the Infinty Beta line, would that be a good fit? (BETA C360). Just curious. Or should I stick to a center from the Primus line? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12007 Registered: May-04
| Posted on Wednesday, January 09, 2008 - 09:15 pm: |
. Buy what fits the space. Once you place a center channel speaker in a different environment than the front speakers, they are no longer timbre matched anyway. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 515 Registered: Feb-07
| Posted on Wednesday, January 09, 2008 - 09:27 pm: |
When in doubt, buy the more expensive one. But seriously, though, I'm a big believer in matching fronts and center. |
