Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Hatchback.
Author Thread: Hatchback.
Username: Transam9425
Hello, I have a 1994 25th anniversary Trans am that is a hatchback. This is my first time dealing with subs and I was looking to put in two high quality 12s. Though I hear subs can interfere with the hatchback door and cause problems? So if anyone has any suggestions or opinions they would be highly appreciated.
Thanks
Username: Slythe
only problem you're likely to get is your hatchback door is gonna vibrate so so much it'll sound like bad distortion (seeing as it's a 1994 model i'm assuming there are a few rattles here and there and in hatchbacks the rear door usually comes first ^_^)...
so fitting decent rubber seals to the door should solve any problems.
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Hatchback. [ « Previous ] [ Next » ]
