Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Input Power (Maximum/Nominal)???
Author Thread: Input Power (Maximum/Nominal)???
Username: Deadhorse
Post Number: 105
What exactly does this speaker spec mean?
Input Power (Maximum/Nominal): 120 Watts/40 Watts
My receiver is 100 Watts per channel so I assume even at full volume I can not damage the speaker but does it mean that optimal usage is with only 40 Watts input?
Username: Gavdawg
Upstate, New York
Post Number: 1047
that is not entirely correct. At full volume, you could very easily blow your speakers due to distortion (among other things).
do a search in the forum for "clipping", and you will get multiples of answers as to why this can happen.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12011
That spec means nothing. At best it means you need at least a forty watt amplifier to go with these speakers. As far as "minimum" wattage goes for a speaker, that's somewhat on the high side. I assume these speakers are not high sensitivity designs.
How would you know when you were using exactly forty watts?
Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Input Power (Maximum/Nominal)??? [ « Previous ] [ Next » ]
