Thread: 4 Speakers Help |
Bronze Member Username: Billru44
Post Number: 17 Registered: Jan-05
| Posted on Monday, December 31, 2007 - 05:04 pm: |
Hey. I'm in the process of building a surround sound system. Currently, I have 2 Front speakers, and 2 Rear Speakers are on the way. Will i get anything out of this (will most receivers be able to recognize only 4 speakers)? I have a JVC RX8040B receiver |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11929 Registered: May-04
| Posted on Monday, December 31, 2007 - 07:51 pm: |
. Geez, Bill, how many ways are you going to ask the same question? I thought you said you had a center speaker. Have you read the owner's manual for this receiver? |
Gold Member Username: John_a
London U.K.
Post Number: 4775 Registered: Dec-03
| Posted on Tuesday, January 01, 2008 - 08:05 am: |
Bill, http://support.jvc.com/consumer/product.jsp?archive=true&pathId=5&modelId=MODL02 7235 Yes, you should be able to set it up to give four channel output. Two "mains", right and left; then two "surrounds", rear right and rear left. I don't know the history. Jan and I and others had big and lengthy discussions on another thread about any extra benefit of a center speaker. For now, just set up the receiver so it knows there is no center speaker connected, then it should distribute the center channel to the R and L main speakers. Ditto with the missing sub. Whether a sub woofer helps will depend on your mains, which will also take the low frequencies if you do the audio set-up correctly on the receiver. In the same way, the missing rear center speaker will be well compensated for. There are not so many true 6.1 recordings in the first place Happy New Year! |
