Home > Message Board > Home Audio > Amps > Archive through January 10, 2008 > Micromix MM4 and peavey SP-4 hook up
Author Thread: Micromix MM4 and peavey SP-4 hook up
Username: Northerncomfort
Sudbury, Ontario
Post Number: 18
was looking for advice.I have a mm4 mixer,has two rear outputs for speakers,rating 4ohm min/total and i have 2 peavey sp-4 cabinets rated 4 ohms.My question is,is there any difference if i hook them up-one speaker per chanel on the amp or hook up one speaker in one channel and run the other speaker off that one.Will there be a different load on the amp???
Username: Jan_b_vigne
Dallas, TX
Post Number: 11909
Uh, yeah. Running loads in parallel is different than not running loads in parallel.
Home > Message Board > Home Audio > Amps > Archive through January 10, 2008 > Micromix MM4 and peavey SP-4 hook up [ « Previous ] [ Next » ]
