Thread: Does Music Come Out of All Speakers? |
New member Username: Billru44
Post Number: 9 Registered: Jan-05
| Posted on Sunday, December 30, 2007 - 01:06 pm: |
Hey, Not sure if this is the right thread, but, here it goes anyway. Until now, i've only had 2 front speakers on my receiver. I'm going to get a center and surround speakers eventually. My question is: when i play CD's and MP3's, will the music come out of ALL speakers or just the front 2? (I know that most music is stereo), but, i was just wondering. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11911 Registered: May-04
| Posted on Sunday, December 30, 2007 - 02:14 pm: |
. How are you going to hook up all these speakers? How you hook them up and what sort of "amplifier" you use will determine the answer to your question. |
Post Number: 10 Registered: Jan-05
| Posted on Sunday, December 30, 2007 - 02:20 pm: |
I have a JVC 8040B receiver and was going to hook up 2 front speakers, 2 rear, and a center. |
Dallas,
TX
Post Number: 11912 Registered: May-04
| Posted on Sunday, December 30, 2007 - 08:34 pm: |
. I have no idea what a JVC 8040B is. Is this a surround system receiver? Does it have provisions for connecting all these speakers as you describe? |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 486 Registered: Feb-07
| Posted on Sunday, December 30, 2007 - 08:52 pm: |
It looks like your JVC is a surround receiver. Most surround receivers have some sort of processing that will allow you to listen to stereo sources using all 5 speakers. It varies from manufacturer to manufacturer as to what it's called, but it's usually along the lines of "5 channel stereo" or something to this effect. Not sure if your receiver has this. It rarely sounds as good as 2 channel stereo, in my opinion. |
Silver Member Username: Nickelbut10
Post Number: 915 Registered: Jun-07
| Posted on Sunday, December 30, 2007 - 09:16 pm: |
Dave hit that dead on. |
Gold Member Username: Exerciseguy
Post Number: 1649 Registered: Oct-04
| Posted on Sunday, December 30, 2007 - 09:27 pm: |
I agree that 2-Channel is usually (and by usually, I mean almost always) your best choice for listening to music, but if your CD or DVD player is capable of playing SACD or DVD-A discs (It will usually state it somewhere on the faceplate of the player), then those formats are capable of playing "surround" music through all 5-channels. |
Post Number: 1650 Registered: Oct-04
| Posted on Sunday, December 30, 2007 - 09:29 pm: |
...did that come out right? |
