Thread: Good sub or not? |
Silver Member Username: Xfacta82
Post Number: 109 Registered: Mar-07
| Posted on Sunday, December 30, 2007 - 11:49 am: |
Sony SA-W2500 100-Watt Performance Line Subwoofer I can get it for 79.99 Is it worth the money? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11907 Registered: May-04
| Posted on Sunday, December 30, 2007 - 12:45 pm: |
. I don't know of a $79.99 "subwoofer" that is a real subwooofer or that is worth owning. Do not pass Go. Do not spend $79.99 plus tax. |
Gold Member Username: Arande2
Rattle your ...
Missouri
Post Number: 2757 Registered: Dec-06
| Posted on Sunday, December 30, 2007 - 07:46 pm: |
The only way to even get any kind of performance at all with that money is to have bought 6 of the EHQS series 12" drivers while they were in stock and mounted them in an infinite baffle, and that's assuming you have some wood lying around along with some old stereo receiver. Ah, whatever. It's really your decision in the end anyway. We only guide the decision. |
Silver Member Username: Wattsssup
Barrie,
ON
Post Number: 166 Registered: Aug-06
| Posted on Sunday, December 30, 2007 - 08:06 pm: |
Seth, what kind of performance do you want from your sub? If all you want is some rumble while watching movies, than perhaps this will be worth the money to you. If you want it to reproduce low frequencies fairly accurately for music, Sony would not be the product of choice. And unfortnutely, it would cost a bit more than $80. Is it worth it? Depends on your expectations. Regards, Marc |
Post Number: 113 Registered: Mar-07
| Posted on Sunday, December 30, 2007 - 08:12 pm: |
i just want some rumble for movies and videogames. I dont listen to music on my surround sound. |
Dallas,
TX
Post Number: 11913 Registered: May-04
| Posted on Sunday, December 30, 2007 - 08:39 pm: |
. What else could you do with $79.99 plus tax? Surely you could do something better than waste it on this "subwoofer". |
Barrie,
ON
Post Number: 167 Registered: Aug-06
| Posted on Sunday, December 30, 2007 - 08:59 pm: |
Well, Jan is much more experienced and knowledgeable on the subject than I am, so I hate to differ, but in this case I will. If all you want it for is a little rumble for movies and video games, you're not an audiophile, the price is right and your expectations aren't exceedingly high, than I say go for it. Here's a link to some user reviews. They seem generally happy with what they got for what they spent. http://reviews.pricegrabber.com/subwoofer-speakers/m/35140442/ |
Dallas,
TX
Post Number: 11917 Registered: May-04
| Posted on Monday, December 31, 2007 - 12:00 am: |
. I doubt whatever I say will stop Seth anyway. It sounds like he has $79.99 (plus tax) burning a hole in his pocket. |
Barrie,
ON
Post Number: 170 Registered: Aug-06
| Posted on Monday, December 31, 2007 - 12:10 am: |
Well, we still love ya Jan...keep on sharing your opinions! |
Post Number: 116 Registered: Mar-07
| Posted on Monday, December 31, 2007 - 09:49 am: |
Is there a better sub for around 100 dollars that I should look into? |
Barrie,
ON
Post Number: 171 Registered: Aug-06
| Posted on Monday, December 31, 2007 - 10:47 am: |
There aren't many choices within your budget. Order this one today (free shipping), and be happy. http://www.amazon.com/gp/product/B0002KVQBA/ref=pd_cp_e_2?pf_rd_p=250314601&pf_r d_s=center-41&pf_rd_t=201&pf_rd_i=B000O8WE66&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0HNXK 7C6Y202NHQ59QDA |
Rattle your ...
Missouri
Post Number: 2760 Registered: Dec-06
| Posted on Monday, December 31, 2007 - 11:05 am: |
My recommendation is to save a little more money and buy something off of eBay or something. If you have a relatively small room, that rumbler may be fine if all you want is a little bit of "boom boom." |
Post Number: 119 Registered: Mar-07
| Posted on Monday, December 31, 2007 - 11:23 am: |
So the polk is better than the sony even though the sony has more power in wattage? |
Barrie,
ON
Post Number: 172 Registered: Aug-06
| Posted on Monday, December 31, 2007 - 11:35 am: |
Don't worry about what Sony says their wattage is, I know it's hard to understand, but it doesn't mean a thing. Yes, the Polk is better. |
Dallas,
TX
Post Number: 11926 Registered: May-04
| Posted on Monday, December 31, 2007 - 02:11 pm: |
. Buy the Polk. |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 5841 Registered: Feb-05
| Posted on Monday, December 31, 2007 - 03:00 pm: |
Buy the Polk Seth...hurry before they run out! |
Gold Member Username: Nuck
Post Number: 9527 Registered: Dec-04
| Posted on Monday, December 31, 2007 - 04:05 pm: |
yep! |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 494 Registered: Feb-07
| Posted on Tuesday, January 01, 2008 - 10:12 pm: |
Buy the Polk. I have 2. |
