Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Help with a new home theater system p...
Author Thread: Help with a new home theater system please...
Username: Captainmichael77
I am building a new system and I would like some help. I have a fairly large living room, well the living room is medium size, but it is open into the kitchen so it makes it fairly large. I will have an equal balance of using it for movies, xbox 360, and listening to music(all types, rock, punk, techno, rap, country). I bought the klipsch quintet sl speaker system and the klipsch synergy sub-12 for 799.99. I also purchased the yamaha rx-v661. I am willing to exchange that receiver for something better or maybe more expensive. Some receivers I was looking at yamaha rx-v861, a pioneer elite, onkyo tx sr605, onkyo tx sr705, onkyo tx sr805, denon, harmon kardon, and i am open to any suggestions, under around $900. And Then I wanted to make this a 7.1 system and add two floor speakers or something that will be able to produce some good sound. I was hoping to spend like $250 or so on each speaker. I am not really to sure what speakers to get but I checked out the klipsch f-1, f-2, and f-3's...So I would like to hear some feedback with some more choices...thanks
Post Number: 8
also i forgot to say.....if it would work, I wanted to take the two fronts from the quintet sl's i have now, and make them rears.... and then the two floor speakers whether they are f1's, f2's, or any other model.. I would like to make them the fronts...reason I suggested the klipsch floor speakers are because I thought they would go together better....please reply with any input, suggestions, or comments...I would like to hear what models you guys recommend for my speakers and a new receiver...
Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Help with a new home theater system p... [ « Previous ] [ Next » ]
