Thread: 9ga. wire for subs? |
New member Username: Coling
Post Number: 1 Registered: Dec-07
| Posted on Friday, December 28, 2007 - 03:38 am: |
I'm about to install my single P3 sub but have a question about the wire running from my amp to the sub. Is it ok to use a large 9ga wire for this? I have alot lying around and would rather use it than buy 12ga if I can. Will this affect anything? Thanks in advance. Colin |
Relevant Product Info
Gold Member Username: Arande2
Rattle your ...
Missouri
Post Number: 2746 Registered: Dec-06
| Posted on Friday, December 28, 2007 - 08:29 am: |
It should be better, especially on a long run. The main benefit is less heat and power losses The only problem might be whether or not it fits the driver and amp connections. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11900 Registered: May-04
| Posted on Friday, December 28, 2007 - 09:58 am: |
. What's a "P3" sub? Is this a powered subwoofer? If so, why aren't you running a low level interconnect rather than a high level speaker cable? How long is the cable run? How much does 12 A.W.G. cost you? Where'd you find "9" guage cable? . |
New member Username: Charmin23
Prairie du Sac,
WI
Usa
Post Number: 1 Registered: Mar-08
| Posted on Monday, March 24, 2008 - 04:48 am: |
if you can get the 9 guage wire to connect and fit. you will have no problem with you system. |
