Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Plan to buy--New Paradigm MM v.5 to o...
Author Thread: Plan to buy--New Paradigm MM v.5 to older v.4
Username: Jerseydevil4ever
How does the new Paradigm Mini Monitor v.5 stack up to the MM v.4? The new Titan seems to be questionable, so I'd like to know about the MM.
Username: Artk
Albany, Oregon
Post Number: 5773
I would take the V4 anytime...a bit more to drive than the new ones but worth it. Keep in mind that there are a lot of other speakers in that price range that compete very nicely, however with your question I would look to save money and get a very nice V4.
What are some of the differences, I can't find anything by Googling. I can buy either in the next few days. I heard the MM v.4 and I was impressed.
Username: Nuck
Post Number: 9467
Neil, what kind of setup did you listen to the v4 with?
Username: Artk
Albany, Oregon
Post Number: 5775
They changed the drivers and crossovers...pretty much a new speaker. The new Mini is not the worst of the new Monitor series however it's not any better (though different) than the V4. All of the Monitor series have become more efficient to produce more volume with less grunt. Meant to get the most from cheap AVR's. However that compromise changed the sound of the speaker and not for the better. If you have the extra few bucks I would look at the B&W 685...killer speaker for just a few bucks more.
Username: Nickelbut10
Post Number: 894
Art is right, the new V5's are a completely new speaker in every way possible. New drivers and crossovers, made in china now, instead of Paradigm making them. They sound like a bag of smashed a$$holes compared to the V4's. They are cheaply made, and very dissapointing giving Paradigms reputation of great speakers for a good price. The good news is that Paradigm is really focusing on their Studio and Signature series speakers, which are better than ever, and still made, fully in house, in Canada. Neil, save the pennies for a bit longer, and buy the Studio 20's.
Thanks. I heard the Studio 20s and they sounded very smooth, but I liked the MMs also. Is there a Studio 20 v.5 now?
BTW, what is the recommendation between the B&W 685s and the Studio 20s.
Username: Nuck
Post Number: 9482
mmmm...maybe the JM Lab focal series.
Neil, what gear did you hear the v4 with?
Username: Artk
Albany, Oregon
Post Number: 5776
"BTW, what is the recommendation between the B&W 685s and the Studio 20s."
Depends on the assocated gear...source, amp etc.
I heard the Studio 20s and MM with Yamahas and Denons at Sixth Ave. Electronics. I spent a lot of time and listened carefully. The Paradigms won out over everything else. I have an NAD receiver that puts out 40 WPC which is really all the power I need. Can I power the Studio 20s on only 40 watts?
Username: Nuck
Post Number: 9483
Is your NAD a 3020? Then maybe, as long as you don't need much volume. That power doesn't really wake up the 20's, I think.
It all depends on what you hear, NC.
Username: Artk
Albany, Oregon
Post Number: 5777
You can power both the Studio 20's and the B&W's with 40 watts, just don't expect live concert volume. I'm powering 4 ohm sealed B&W 610i's with a 30 yr old 40 watt per channel Sansui receiver and it works beautifully.
Username: Nuck
Post Number: 9484
Like that, Art. You are not going to get what the speakrs are capable of, but maximizing the amp has a lot to be said.
Username: Artk
Albany, Oregon
Post Number: 5778
As Nuck said you won't get all that the speaker is capable of, but it should make for good music making none the less.
What's a good price for Studio 20 v.4s in nice condition? $550.00 to 650.00?
Username: Nuck
Post Number: 9488
Its what you want to pay, Neil.
If you want these speakers, you must factor in the stands.
Art, how about stands?
Neil, Art ran these speaks with a Rotel amp to very happy results.
Username: Artk
Albany, Oregon
Post Number: 5783
"Art, how about stands?"
How about them? Buy 'em....
There are a huge variety of online stores for stands but if you're buying from a dealer I'm sure they have recommendations if not a good 20-24 inch metal stand should work fine.
As far as a good price for used ones I don't know, haven't bought them used. Whatever you are willing to pay is the best price. Seems like your range is reasonable but I haven't looked to see what the demand is on that speaker.
Username: Nuck
Post Number: 9489
A 24" would put the 20 at ear level with a standard height chair.
Gotta keep the tweet at ear level.
The only time I heard the 20's with Classe power they had very heavy stands.
Username: Mr_audio
St. Louis, MO
Just my two cents about v.5 Paraidgms. I've heard both and own version 4 mini monitors. At first the v.5 seems to be alot clearer and open, but I can't listen to them for a long time because they sound too biased to the highs. The v.4 mini is a little the other direction. They sound a little too dull. In the end I thought the v.4 won out because too dull to me is better than to sharp and bright. The v.5 monitors sound really agressive compared to other Paradigms. I recommend staying away from Denon if you get v.5 as Denon will amplify these annoying traits.
Post Number: 907
lol a Denon and Paradigm combo would be like running nails down a chock board.lol. I agree with Kenny.
Username: Gavdawg
Upstate, New York
Post Number: 1020
That makes about as much sense as pairing Klipsch with Sony or Onkyo.
lol
Home > Message Board > Home Audio > Speakers > Archive through January 30, 2008 > Plan to buy--New Paradigm MM v.5 to o... [ « Previous ] [ Next » ]
