Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Subwoofer Connection
Author Thread: Subwoofer Connection
Username: Bruces10
Tuscaloosa, AL
Please, help a guy out....after much delay, I am putting together a home theatre system which incorporates a new receiver (Yamaha RX-V659)to a subwoofer (JBL PB12) which I have had for a few years. I will be running the subwoofer cable through the walls and will need a run of approximately 38-40 ft. What brand/type cable would you recommend I use for this?
Secondly, in the past, I had this subwoofer hooked up to an Onkyo TS-DX676 receiver using RCA dual (L & R) plugs to the Line Level In L & R connections. However, it appears that the Yamaha receiver (RX-V659) has only one place to accept a RCA plug-in. What type connection/cable would you recommend I use in this case?
Thanks.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11876
Call these people; http://www.parts-express.com/
They will answer all your questions and suggest a cable in your price range.
Username: Bruces10
Tuscaloosa, AL
OK. Thanks for the advice, Jan.
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Subwoofer Connection [ « Previous ] [ Next » ]
